MGB V8 conversion - oil fill location?
Only Post In Here With A Picture Please,
It will help us spot each other at shows etc,
This is a private forum,
Only the members can see here.
JohnV8#
Post by JohnV8# »
Guidance needed on oil fill location! Thanks.
Quinten
Re: MGB V8 conversion - oil fill location?
Post by Quinten »
Normally there would be an oil filler on one of the rocker covers, and an oil breather on the other. You appear to have breathers on both sides. Could you have a dry sump system with a separate oil cannister elsewhere?
2002 Westfield Seight 3.9EFI
JohnV8#
Post by JohnV8# »
A standard wet sump I believe.
Two breathers are unnecessary as the engine is open internally. You may just be able to pull one off, pour the oil into the rocker cover and then pop it back.
JohnV8#
Post by JohnV8# »
Thanks - both breathers pull off so will check that option.
As above, just pull a breather off and fill via that.
Return to “Members Pictures Only,”
