The fuse holder will need replacing. The reason for the fuse blowing is currently unknown, although the car sat unused for a couple of years, the fans ran for while yesterday with the car idling, and then the fuse blew. The mess that was a fuse probably indicates that it's not just an issue with an old fuse.
In case this turns into a saga of blown fuses and damaged fuse holders, I might fit a minature circuit breaker for easy re-setting, e.g.
https://www.screwfix.com/p/schneider-el ... -mcb/1325p
Any views on fitting an MCB instead of using a blade fuse?
