What torqueconverter fits a 727?
BlesvikRacing
Post by BlesvikRacing »
I have been searching summitracing.com for a new 10" 3500rpm stallspeedconverter for my new 727 that I took from a RangeRover 3,5.
Is it a dodge, amc, chrysler or a spesial rover type?
BlesvikRacing
It's AMC :wink:
JP.
Post by JP. »
727 = Torqueflite.
Torqueflite = Mopar (Chysler/Dodge/AMC)
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
BlesvikRacing
Yes, but do Chysler/Dodge/AMC have the same converter??
alex
Post by alex »
Its a Little confusing as to what it is.
If it came from an early rangerover its a torqueflight but it you look on the side it says 998 I think. This is a hybrid of a 727 and 904. im also not sure if it was a v8 or 6cyl box. trying to find out myself at the moment. A couple uf usefull links.
http://www.coperacingtrans.com/index.htm
http://www.converter.cc/index.html
http://www.allpar.com/mopar/torqueflite.html
Alex
ps let me know if you find out.
alex
Post by alex »
Hi again.
Mine is an 11inch converter if that helps.
You can have them rebuilt if you have the original one. Mine cost £100 but is at standard settings.
Make sure you have the flex plate and the 2 spacers one on each side as these spacers are almost impossible to get new.
Alex.
BlesvikRacing
Thanks for the links and info Alex!
On the side of the tranny I found this number: PK3836023 8595 3432
But I sent the converter to modifying today.
The shop told me they could put the stallspeed up 7-800rpm.
:cry: :cry: :cry:
alex
Post by alex »
Hi there.
I see you had a bit of bad luck :(
I managed to get hold of the crank side spacer from John Craddocks, a land rover parts place with lots of old stock, Give them a try or if you want Ill pop in on friday.
I suppose it would be possible to have one turned up locally aswell.
Alex.
alex
Post by alex »
As for the number there is one on the side looks like someone wrote it on freehand in alluminium. If that makes sense I think thats where it relates to 727, 904, 998, Ill take a closer look when I get my car back hopefully this weekend.
Alex.
BlesvikRacing
I canceled the modifying and ordered this one: http://store.summitracing.com/partdetai ... toview=sku
I hope it will work for me.
Alex.
Were is this number?
I found this:
