Hi Dave
It's a narrow band Lambda; came with the kit. Although, I did fit a Stack Wide band a few years ago to help me tune the Weber, and it's still there but just runs a gauge on the dash now.
The wiring loom was supplied, i.e. about 20 or so rolls of wire, wrapping tape and a load of fittings. I must admit I did have fun with that lot.
Running MS1 V3 (I think) I am really new to all this and have no idea how to tune it. Just starting out so in the steep learning curve stage
There is a huge hole in the bulkhead, where the steering fits if you want LHD, so all the wiring is going through there. I'll cut a hole in the middle of the rubber bung and then fit a smaller rubber grommet into that. That way I should be able to remove the loom if I ever need to.
The engine spec (from the advert when I bought it) is:-
4 litre cross bolted V8.
Pair of stage 1 unleaded RPI engineering cylinder heads.
Piper RP4 high torque cam and followers.
Cloyes duplex timing chain and sprockets.
Lightened and balanced flywheel.
High torque gear reduction starter motor.
Mallory dual point distributor.
RPI engineering A&P electronic ignition power amp.
Correct ignition coil and ballast resistor.
Magnecor 8mm plug leads.
Offenhauser dual port inlet manifold.
Weber 500 carburettor.
J&P stainless exhaust manifolds with 13/4 primaries.
Custom 2 into 1 front section of exhaust.
Stripped and rebuilt LT77 5 speed gearbox.
Bloke spent loads of money on it then sold it to me cheap
. Weber and other stuff has obviously gone now. Picks up well though, or I hope it does if I ever get the engine tuned.
There was a wiring diagram supplied to make the loom with and I have changed it slightly, so have altered the diagram accordingly and printed it off. In the manual with the original now. I learned that lesson.
