I bought mine from the web as I wanted it in blue and were much cheaper however came with naff jubilee clips.
As you can see, I used the original tap to put in a pipe to my header tank and added a new tap to fit an otter switch controlling my fan. For the latter I bought some cheap taps.
I've removed the swirl pot since this photo but it shows my header tank on the left. I cannot position it higher but it is just (only just) higher than top of engine but seems to work OK.
I have been told that I should have taken a pipe from the outlet* just to the right of the ECU water temp sender and almost under the air intake and near N0 1 injector to a new inlet in the top of the header tank, then another pipe from bottom rad hose to bottom inlet of header tank. That way it should keep everything air free.
*You can just see this rubber hose to the right of the brown ECU sensor. My engine came with a short rubber hose from this outlet but plugged with a bolt. I can only assume TVR did this or was it a standard Disco RV8 feature?
I've now replaced this bolt with a fuel pipe on/off valve making it easy to bleed air out and indeed fill the last bit of coolant into engine.
Richard.
