I'm going to fit the temperature sender unit to my Edelbrock manifold - should I use PTFE tape or anything like that to ensure a good water tight seal, or can the device simply be bolted in place?
Alex
Temperature sender unit
Re: Temperature sender unit
If it is a taper thread then a couple of wraps of PTFE tape will seal it well. Don't make the mistake of wrapping forty layers on it like so many people do. Test fit it to see how much thread actually goes into the hole, then try to make sure the tape doesn't go further up the thread than that, so it looks neat and tidy after you finish.v8alex wrote:I'm going to fit the temperature sender unit to my Edelbrock manifold - should I use PTFE tape or anything like that to ensure a good water tight seal, or can the device simply be bolted in place?
Alex
If it's an electric unit best advice is ~NO
Get a shitty earth and the gauge is all over the place
Hence the 2 wraps instructions.Ian Anderson wrote:If it's an electric unit best advice is ~NO
The idea being that the tape merely fills any small gaps left between metal to metal seal.
The forty-wraps brigade can easily achieve total electrical insulation and also have a great booger lump of tape poking out, showing the whole world that they know nothing about anything.
- Andy515666
Hi guys
Just reading your post and this could explain to why my temp guage was so off.
I too used the tape to seal betwen temp sender and inlet manifold. I didnt stop to think that this would cause an issue with the earth.
My gauge rises and keeps on rising past 110* (at whcih poit i turn the motor off) I listen and can hear no boiling noise and the motor does not seem to be overheating.
I removed the thermostat and checked, same problem.
I have ended up putting on a new water pump, had the radiator re-conidtioned/re-cored.
Could the earth to gauge be the issue here? (too much tape wrapped around the sender unit?)
Chur Bro
