Cooling issues.
Re: Cooling issues.
You could be right. As long as any air bubbles that rise to the top have a way to get out, then that's OK. So if your radiator is higher than that, then the radiator vent will be OK. But if that is the highest point, then you will need it I think.
Re: Cooling issues.
good point.........ill have a think about that one before I decide.....Just ordered some additional pipe work so when it arrives I'll give it all a go and report back......thanks Chris for the advice.
Building a westfield V8
Re: Cooling issues.
Just to add to the confusion, there are 2 different thermostats that look superficially similar, the P38 and the Discovery.jenko wrote: ↑Sun Jul 19, 2020 5:04 pmJust looked at a load of other diagrams, and I agree, I seem to be completely wrong...god only knows how I ended up getting it so wrong. looks I need one of these, and remove the thermostat from the inlet manifold (but why is there a perfectly machined cut out)......looks like a robotic heart!.
There may also be differences between the diesel and petrol engines, too, but I am not sure as I have not been that deep into them yet.
My P38 is the 4.6 and my Disco is the Td5, and like I say, they look very similar, but are in fact, quite different in the plumbing.
Re: Cooling issues.
I've ordered the P38 version as this appears to be 85 degree stat...more importantly, now I've researched these things there is also one other crucial function that was missing from my last set up (and quite possibly the reason for my problems). Its regarding the thermostat bypass pluming. the internal thermostat on these also has a disc that, when open blocks the thermostat bypass.....eureaka (I hope), my previous set up did not have any such feature (sounds obvious now), which means that possibly a third of the water circulating bypassed the rad!.unstable load wrote: ↑Wed Jul 22, 2020 6:32 amJust to add to the confusion, there are 2 different thermostats that look superficially similar, the P38 and the Discovery.jenko wrote: ↑Sun Jul 19, 2020 5:04 pmJust looked at a load of other diagrams, and I agree, I seem to be completely wrong...god only knows how I ended up getting it so wrong. looks I need one of these, and remove the thermostat from the inlet manifold (but why is there a perfectly machined cut out)......looks like a robotic heart!.
Re: Cooling issues.
The P38 one is 95 degrees as far as I know...jenko wrote: ↑Tue Aug 04, 2020 7:36 amI've ordered the P38 version as this appears to be 85 degree stat...more importantly, now I've researched these things there is also one other crucial function that was missing from my last set up (and quite possibly the reason for my problems). Its regarding the thermostat bypass pluming. the internal thermostat on these also has a disc that, when open blocks the thermostat bypass.....eureaka (I hope), my previous set up did not have any such feature (sounds obvious now), which means that possibly a third of the water circulating bypassed the rad!.
Interesting point about the internal disc - I will have to have a look into that - I was unaware of that!
Re: Cooling issues.
Ahhh...95 feels to hot, but it might be ok....I wonder if there is an 85degree version?.ChrisJC wrote: ↑Wed Aug 05, 2020 8:58 amThe P38 one is 95 degrees as far as I know...jenko wrote: ↑Tue Aug 04, 2020 7:36 amI've ordered the P38 version as this appears to be 85 degree stat...more importantly, now I've researched these things there is also one other crucial function that was missing from my last set up (and quite possibly the reason for my problems). Its regarding the thermostat bypass pluming. the internal thermostat on these also has a disc that, when open blocks the thermostat bypass.....eureaka (I hope), my previous set up did not have any such feature (sounds obvious now), which means that possibly a third of the water circulating bypassed the rad!.
Yes the internal cut off is an interesting one......I found this very useful diagram on google, that shows how it works.....but it makes sense.
Re: Cooling issues.
Just had a quick look around....some refer to them as 82 degree...now Im really confused!:
https://www.onlinecarparts.co.uk/oenumb ... 01130.html
https://www.amazon.co.uk/U-ESSENTIALS-C ... B078LKW14M
Anyhow...it could be that its fine as 95 stat...I think I just need to give it a go and see what happens.
Re: Cooling issues.
My understanding that the P38 one only came in one temperature.
The Discovery II V8 ones came in at least two temperatures, but they are a totally different design!!
Re: Cooling issues.
I think the Freelander stat is 82° just to add confusion ![EEK :eek](./images/smilies/eek.gif)
Re: Cooling issues.
I received the thermostat today....it is indeed 82degrees...i wonder if they started doing some after market ones as my Haynes manual also suggest they run at 95...
And here it is installed...definitely an artificial heart!.
- Seight-V8
- Knows His Stuff
Re: Cooling issues.
has anyone used this thermostat from a TVR before....its not cheap i know...but you can put you own thermostat inside, where the LR one is not replaceable or servicable.
https://www.ebay.co.uk/itm/Upgraded-The ... SwIDBb2uX3
regards
scott
regards
scott
Re: Cooling issues.
Never seen one of those before....looks like it has three 32mm ports. As it happens, I did buy the longer part for my connection to the inlet manifold (i.e. feed to top of rad).
Re: Cooling issues.
Another benefit of the remote thermostat housings is they close off the bypass circuit as the stat opens so you get 100% flow through the rad - doesn't look like that billet one does that?
Re: Cooling issues.
There are thermostat housings available that you can swap out the stat, but they are all aftermarket.
Re: Cooling issues.
Use waterless coolant. No rust, no boiling take the cap off no explosion. All solved. Now you lot will say u never heard of it so its too far from mainstream. Carry on heating yo then. U all love a natter about this yet I just solved your issues
Anything that's new or different to anything u lot know has to be wrong
