Caliper Positioning
Rossco
Moderator Gold
Moderator Gold
Caliper Positioning
Post by Rossco »
Does anyone know any good reason why a caliper cant be mounted on the leading side of the disc rather than the trailing side?
DEVONMAN
Re: Caliper Positioning
Post by DEVONMAN »
Rossco wrote:Does anyone know any good reason why a caliper cant be mounted on the leading side of the disc rather than the trailing side?
There are plenty of vehicles out there with calipers on the leading side.
Regards Denis
there meant to be small advantages to mounting front calipers behind the axle centre line and the rears in front but the advantages are not large and at the moment I can't remember why, as said above there are many cars that don't do it that way and they don't have problems stopping.
Most simple answer is yes because of the steering geometry and where the steering arm connects.
Also irrespective of where the caliper is fitted you need to ensure the bleed nipple is at the top - sounds silly but you'd be amazed how many people fit calipers upside down! (Bleeding is then a big problem - remove caliper and hold right way up etc)
You quite often see rear discs like this.
Could it be anything to do with road grit and water etc?
DEVONMAN
Post by DEVONMAN »
Maybe the disc cools better with the caliper out of the way of the air stream especially with air ducts fitted.
Regards
Denis
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
Cheers for all the replies guys.
Pretty much reflects what I thought.
