Overhauling Lockheed brake booster
RoverP6B
Post by RoverP6B »
I am in the process of overhauling my spare brake booster for my Rover P6B.
The slave cylinder has been previously resleeved, and I have the genuine Lockheed kit for the complete assembly.
My question though relates to the condition inside the vacuum chamber.
The was quite an amount of corrosion which has now been removed, but I fear that if I leave the surface bare without any form of protective coating, the same will happen again.
Should the inside surface be painted? If so, what type of paint is resistant to brake fluid? Or should the surface just be left bare metal?
Any thoughts wil be highly appreciated.
Ron.
4.6 Rover 3500 P6B
If I was being a perfectionist, I'd try to get it plated rather than painted.
RoverP6B
Post by RoverP6B »
Hello Chris,
By plated do you mean chrome plated?
I have also seen brake calipers advised as having been plated.
Ron.
4.6 Rover 3500 P6B
if you can heat the relevent bits, I would get it stove enamaled (not powder coated), I can't think of many things that resist brake fluid but stove enamaling is one. Just remember the surface is not as mechanically tough as powder coating.
I meant Cadmium plating, that kind of goldy colour that these things often have when new.
