Does anyone use an adjustable brake bias valve? which should i use and where can i get one? i'm fitting a rear disc set up to the rear of a triumph TR7.
Thanks.
Brake bias valve
My MG has a wierd set up for the bias valve. There is a dial in the cockpit which runs to an adjustable bar in the pedal box. I have two Wilwood master cylinders, of different sizes (one for front, one for rear), which are fed by a common alloy brake fluid reservoir.
It was already on the car when i bought it, but I can sort you a few pics out later if you like? Can even supply the part numbers i think as half of it is dismantled at the moment lol
Personally I doubt if the valve will have big effect as with the rear of the TR7 being so light most of the braking should be on the front anyway, (the standard valve only limits the rear and be very carefull with setting the new valve as rear wheel lock up is pretty frightening). If the brakes work well when presssed firmly then you need to fit a larger servo or different pads many peole have fitted SD1 servo's in the past, I have also had great results with Greenstuff pads.(it they work bettter after repeated applications then it is almost certainly the pads).
Kevin
Kevin
Kevin S
