Before I get shot down this is just a for instance, not an idea as such ... but I saw these babies on ebay;
http://www.ebay.co.uk/itm/331029075899? ... 366wt_1179
Apart from the aesthetic and unquestionable abiltiy in the brake department, what's the chance of these being used on a road car, or fast road/track car? I've seen Formula 1 brake calipers fitted to the odd custom race/track car in the past (Liam Doran's RS200 has them for the Pikes Peak).
You can still get pads and parts for them, they fit relatively small disc diameters (circa 300mm), the only issue I can see is the lack of dust seals etc (well they are race calipers!). I just thought they looked great and are not actually bad for the money, compared to other AP caliper kits etc.
AP Racing Monobloc Calipers - Formula 1
The only issue is exactly as you say, no seals, this is not a problem if they are maintained as intended,are you prepared to wash off the road salt every time after use? strip them once every 3000 miles or so to inspect them, most definatly replace the brake fluid every spring? I have racing brakes on my motorcycle That is fine for the amount it was used when I used the thing. They are nice brakes, but they are priced like that for a reason if you are happy with the maintanence then they are good value, if not save up for some with seals.
I wouldn't discount the brakes fitted to things like lexus, ford mondaos, Jag XJ, XK and S types Mercedes etc these modern standard brake calipers are very good value kit. The refurbished standard kit that offers a very high standard of stopping power at a briliant price. If you are OK cleaning it up yourself I can send you a set of Lexus 400 front calipers for the cost of the postage, they would need a strip clean and refurbish but I recon they would stop an MGb in pretty short order.
Hi Mike, thanks for the offer that's very generous but I'm currently sorted for brakes (sierra 2wd rear, Jag XJS fronts) and will be buying either an LS400 or Soarer complete car for engine/box/loom so will have a choice shortly enough!kiwicar wrote:Hi
The problem with OEM brake calipers is the weight, seriously my Jag XLS calipers must be about 10kg per side! These monoblocs are super lightweight with ti pistons etc. and would give huge savings in unsprung weight in any car versus pretty much any other brake option! Not a bad price either, considering what they are new!
Hi Dave
many have a seal inside the cylinder of the caliper, often an O ring but not always it can be stainless, the seal is not visible and is as you describe when viewed form the outside. True also some have no seals at all, however they are not made of Aluminium alloy and titanium, they generally are stainless steel pistons in hi chrome steel casting.
