Does anyone know what is the thickest disc the series 2/3 xj jag calipers will fit over?I am pretty sure 24mm is standard but the new rotors on my SD1 are 28mm x 300mm and im concerned they wont go over them.Thanks in advance.
Doug
jag calipers
re
i figured it might be tight,I have the option of using the standard SD1 4 pots with the spacer plates used on the Rangie vented disc conversions,but the pads are a fair bit smaller than the jag ones.Might look at the PBR twin piston alloy callipers,pads are bigger than the jag and the calipers are about half the weight.
Doug
Doug
Update - Bigger Discs
After some thought,I have fitted 322mm x 34mm discs ,so will need caliper spacers for sure.does anyone know where I can get hold of some or will I need to fabricate them myself?
Doug
Doug
re
Thanks for that.Did a final measure up today and have settled/purchased a pair of 312mm x 32 mm grooved discs,the larger ones were over 2 kg heavier and I am adding a bit of unsprung weight as it is.Look awsome sitting in the Momo wheels though as opposed to the piddling standard ones.
Doug
Doug
