Jensen/ rover P5 brake conversion
- truckdoctor
- Helpful or Confused
Hi all, any brake guru's care to help with a big problem I have in sourcing rear discs and calipers to fit to a Salisbury HA axle originaly fitted to a Jensen, thats going into a Rover p5b coupe as it has a 2.8:1 limited slip diff. As these original parts are formidably expensive I'm looking for alternative parts that may fit or may need a bit of modification.
As you can imagine trying to find parts amongst so much choice is bewildering but have seltled so far on Mondeo parts, any thoughts please.
Here's a few pics of the unit so far.
Home made hub puller removing the tapered joint.
If dimensions would be helpfull then its all available, just to help , stud pattern is 5 on 5 etc.
Thanks so far, Steve
You can enter the various disc parameters in the Brembo site and see what comes up.
http://bremboaftermarket.com/En/Car_Dis ... hMode=Size
- truckdoctor
- truckdoctor
Well that's strange, after putting mondeo sizes in , it's still not working for me?DaveEFI wrote:Works ok here. However, you have to enter the correct parameter - it won't give you the nearest.truckdoctor wrote:That's a good idea Dave, unfortunately that site's not working!!!!!!!!!!!! Any others you know of please?
- truckdoctor
OK Thanks, here we go thenkiwicar wrote:Hi
I have a small collection of un used brae discs from jags, vectras, RRs and siera (i think)
If you post up PCDs and diaiters I can have a measure up and see if any are suitable.
Overall diameter 275mm
Thickness 12.5mm
Height 50mm
Holes 5
Distance between hole centres 65mm = to 110.58 mm PCD
Locating hole diameter 85mm
Thanks, Steve
- truckdoctor
You can also look up by make etc and see if those dimensions cross reference on the search back to that make and model. If not, it may be a browser problem. It works fine here with Firefox.truckdoctor wrote:Well that's strange, after putting mondeo sizes in , it's still not working for me?DaveEFI wrote:Works ok here. However, you have to enter the correct parameter - it won't give you the nearest.truckdoctor wrote:That's a good idea Dave, unfortunately that site's not working!!!!!!!!!!!! Any others you know of please?
What do these use for a handbrake?
You might also look at the Saab 900 and Vectra calipers (fronts) as they have the handbrake work on the froont wheels
