lexan glass
lexan glass
Hi all, what is the minium thickness it should be for a road car, rich
Hi Ian, i only do drag racing, but not sure why im doing anything else to the car as next year my nephews might be using it more than me .Will go 4mm ,thanks for the reply rich
Take the lexan and use an offcut
Get a big baby bath thing and mix up some Dyola fabric dye (your choice on colour)
Stick in the offcut
give it a few minutes and check the tint
If not dark enough stick it back in
Take the total submerged time
Then use this time for your pieces you need to use - you can make it darker but not get the stuff lighter again
Stick in the offcut
i never knew that either, i was planning on buying some tint film and sticking it on, rich
OK got to 'fess up.
My company supplies both Acrylic(Perspex) and Polycarbonate(Lexan). We can only supply rectangular shapes off the panel saw until we get our CNC router. Not sure of our competitiveness against national suppliers but if someone wants to give me some sizes then I'll TRY to give a good price to Forum members (and if not you can all talk about me behind my back later ).
The problem is you need to buy in multiples of half sheets
The full sheet sizes for 4mm Polycarb are
PC 000 Clear 4mm
3050 X 2050
2440 X 1220
2050 X 1525
Half sheet sizes are
PC 000 Clear 4mm
1525 X 2050
1220 X 1220
1025 X 1525
Use Polycarb for motorsport and Acrylic for cheap mirrored bedroom ceilings.
If you can't make a half or full sheet then get together for a group buy. We cut to size free of charge (rectangular only).
Hope this helps
PC 000 Clear 4mm
3050 X 2050
2440 X 1220
2050 X 1525
PC 000 Clear 4mm
1525 X 2050
1220 X 1220
1025 X 1525
Hope this helps
It's an engine Jim.....but not as we know it
this is what ive found so far, 4mm ,2050x1250 £108.80, 2440x1220 £126.39, 3050x2050 £265.47. all prices are plus vat, rich
Good thing to get into is light covers and windows for GT40s
Need to heat mold them into a small curve though!
Hi Ian, how much is delivery , and can tint film be put on the lexan??. i will have to measure up how much i will need, cheers Rich
