hi recently fitted a 3.5 v8 into a land rover defender the engine was out of a range rover classic it had a long oil filter fitted to start with ,
after a few days running i noticed the front axe was hitting the middle of the filter body small dent ,
so i changed the filter for a shorter one coopers z1159 but now its hitting the filter body right on the end . does any one know of a shorter filter that i can fit . I know i could get a remote filter kit but i don't like parting with cash . thanks in advance.
diffrent oil filter
i run a sierra filter on the capri
cant remember the number at present,
Ford part number EFL 90thev8kid wrote:i run a sierra filter on the capri
I tried one on my Rover engined Sierra but it took longer than expected to get the oil pressure up if it had stood fo a while, in the end I got one from Real Steel that must have had some kind of a one way valve, I think it was a Chrysler one but it was a long time ago and my memory is not as good as it used to be
Mark
mine was a coopers filter not o/e ford one mate.
