Winter Hibernation. What mods are YOU doing ??
i have tried to complete some jobs in this cold weather
fitted new thick radiator and refitted the cooling fans back to it.
changed the engine oil and filter, it maybe overkill as less than 3000 miles a year is not a lot of miles yearly.
2010 season end
fitting new supercharger and trigger wheels kit. ECU etc, in tank fuel pump etc....
maybe out for 2011 during refurb work
Andy
2010 season end
Andy
3.9 V8 Mini Van....THE BEAST
Change front and rear suspension for coil overs
Fit roll cage and seam weld shell
Change of gearbox to th400
Replace rear axle to ford 9"
Rewire all electrics
Cut body and fit arches
Change fuel tank to fuel cell and fuel pumps
Fit bucket seat and new belts
AND what have i done???? took some of the crap thats pilled up on top
of her off so getting there LOL want to be at Pod for late FEB some how
Tricky
You aint on your own Trick!!
I've done bugger all as well
Although I did speak to the machine shop an hour ago to find he actually had one of my wheels on his rotary milling lathe flypress turntable wotsits in order to start re milling the rims to MGB stud pattern
This was going to be a quick "£80 in your back pocket job" but he just told me he's made up a bush of some sort and done a cad drawing or something. I think I'll be getting a much bigger bill than I expected
I only wanted 8 holes drilled. But I suppose he is doing it the right way eh? I didnt want to risk doing it on my £30 pillar drill
Good news for me!!
The rims only cost 60 notes in the end.
So the tyres are now fitted and the rims are on the car. I did have to get the grinder out to get them in the arches though.
So today i decided to finish work and get something done to the car. I got home at 8pm, peeing down with rain, looked at the car and thought sod it !!
I'll play tomorrow [/url]
nice one mate,
i must pull my finger out and sort mine out,
but lacking enthusiasm,
pity we didnt live nearer you could give me a kick then,
my biggest prob is having somewhere to work on the car
Well, like most I haven't got the enthusiasm to do stuff but... I'm in the workshop in the morning to strip and re-grease both hubs and do the tracking on the front axle of the bobtail then "pop over" and sort out one of my MegaSquirt conversions that is playing up. It's the TIP122 that's squiffy so I will cut the old one out and solder the new one in then try and get home before dark..... I love V8's..
jeff
jeff
ah could that be the scooby?
have made the tool for removing the stem seals mate so fingers crossed next weekend we cure the smoke,
and the two cylinders that have black plugs
regarding the electronics bit,
sooner than later, as i have posted on vems tonight some weird things the ecu is now doing
well the diff and axle are done and the induction thing is almost finished. front lights are done, so the list is getting smaller rich
sweet mate,
hope to have my engine out in 3 weeks time, and re ring it and back together,
