Confused about multivalves
mr_s
Post by mr_s »
I'm confused.
The way I understood it was the multivalve shut the gas off from the rest of the system unless the solenoid was activated.
This doesn't seem to be the case, I've tried 3 multivalves now (including one brand new one), and all of them release gas from the pipe that feeds the system if I undo it at either end.
Am I just barking up the wrong tree and the valve doesn't really shut the supply off, or is something wrong?
To recap, I've got the solenoid on the multivalve, which then goes via a 6mm pipe to another cut-off solenoid in the engine bay, which then goes via another 6mm pipe to the vapouriser (which also has it's own solenoid).
Cheers, Martin
1975 Chevrolet Blazer K5 400ci Pickup
1990 Mercedes 420SEL
1995 Jeep Cherokee (non V8... Doh!)
Various bikes 'n bits
Building a 4-car garage :D
LazyDocker
Post by LazyDocker »
Is this definitely a constant flow or is it just venting the pressure already in the pipe? From my very recent experience, when fitting an additional tank, I know that it does sometimes seem to take forever to vent!! Have a little commitment and chance leaving it for a while after cracking the nut and see what happens!! ( I would advise doing this with as little LPG in the tank as possible just in case!!) Mine definitely shut off at the tank.
mr_s
Post by mr_s »
Nope, it definitely keeps going until all the gas is gone... I changed the multivalve recently on one of my tanks, ran the car on idle until the gas had almost gone, then it took a good hour or so (only undid the pipe that runs to the engine bay a little) to let the rest of the gas out. Then, when I undid the multivalve via it's 6 bolts, there was no further release of pressure...
Could it be that I have 3 faulty valves, including the new one I just put in?
The more I play with LPG, the more I love petrol! lol
Cheers, Martin
LazyDocker
How curious!!!! Have the multi-valves got manual shut offs? I'd be a little concerned if they aren't shutting off the flow though!!
As for LPG... I love it!! I run a V8 Rangie for less than the wife's 1.8 Orion!! Although I do seem to spend all my time fixing the bodywork!! :roll: :roll: :roll:
The multivalves I have got definitely shut off flow unless there's power on the solenoid.
What you describe isn't very failsafe!!!
mr_s
Post by mr_s »
Which is exactly my issue...!
I'll take pics of the valves, just to make sure I'm describing them right...
Cheers, Martin
Return to “LPG Section”
