What supercharger?
What supercharger?
Looking at getting a supercharger for the rover v8 with the weber 500 but not sure what will fit or best etc. How much roughly for a decent one and precautions before chosing.
if it has to be used with a 4 barrel then it looks like you are stuck with a roots blower, therefor a 3-71 or a 4-71 depending on engine size and how much boost you want, budget between £2000 and £2500 for a kit ready to bolt on.
If you are prepared to go away from a 4 barrel then a centrifugal blower is much smaller.
- topcatcustom
Hi Tom
yes I know quite alot of american set ups are blow through 4 barrels, just they are such a lousey solution to getting fuel into an engine that I don't even consider them an utter bodge!
if it has to package into a small space then s centrifugal blower, injection fueling and megasquirt would be the best solution, otherwise just cut a big hole in the bonnet, can't think of anyone who would use that as a solution
best regards
best regards
- topcatcustom
I tried that and it got expensive to find a few extra hp.... Cost me about £1500 on engine tweaks to get my old 3500 MGB V8 up from 130hp to 187hp.Mongman wrote:Was just a passing interest as i saw chargers on ebay saying they were for the rover v8 and curious how good they were. May just go for better cams and a few engine tweeks.
But then I fitted a stock 4.6 RV8. This makes 202hp on the carb.
Then I fitted the GMC 4/71 blower and at half boost of 7psi she makes 350hp with 500 ft/lbs of torque.
Get a loan, fit the full blower kit and have some fun
