4.6 rover V8 centrifugal supercharger boost/ power limit?
- Knows His Stuff
- topcatcustom
I wouldn't say useless, I have seen quite a few motors with blowers running on V belts, not the most efficient but no problems either. You wouldn't use the one for your alternator either, straight off the crank pulley, maybe go double, though a ribbed belt would be better or a narrow toothed belt.crayefish wrote:put some fairy liquid and water solution around the injector o-rings. if you get bubbles, they are leaking on boost
Looks like a pretty compact but nice setup. yeah V-belts will be useless for a supercharger unless the tension is very high but that would destroy your alternator bearings etc
TC
If you were going to the effort of a double groove pulley, then it wouldnt be a long stretch to get a toothed belt and pulleys. It is possible to get belts and pulleys etc from companies like RS components pretty reasonably priced, even though they are not designed for blower applications originallytopcatproduction wrote:I wouldn't say useless, I have seen quite a few motors with blowers running on V belts, not the most efficient but no problems either. You wouldn't use the one for your alternator either, straight off the crank pulley, maybe go double, though a ribbed belt would be better or a narrow toothed belt.crayefish wrote:put some fairy liquid and water solution around the injector o-rings. if you get bubbles, they are leaking on boost
Would a serp belt be a fair compromise perhaps? I am not sure if it would offer more grip.
Zander
eatons etc use serp belts
Dont worry about the CR. The boost delivery from the CF blower wont cause any hassles if its tuned correctly.
Im near enough 9.5:1 now and running about 20psi at 7000rpm. Different engine, but not vastly different.
Remove your rocker gear, and pressure test the entire system
From blower inlet through to the intake valves. Make up a fitting for the blower inlet and hook up an airline via a pressure regulator. You'l soon find any leaks.
Can I watch, that will be fun someone lying on the front of the car with their head under the bonnet while you accelerate under load building boost so they can look for bubbles comming out around the injectors
- topcatcustom
Yes, That was always the issue. I wasn't able to put any load on the engine to test for leaks. My new inlet manifold is designed for the o-ring type injector anyway so that should eliminate that.
Well I feel better about my 9.5:1 compression ratio after your comments.
I'm going to stick with that. I plan to get it tuned on a rolling road so will make sure it is not detonating. I'm aiming for 8-10 psi which i'm sure will scare me enough!!
I only had the v belt driving the supercharger, nothing else, (using the spare v pulley on the rangerover crank pulley) I calculated it would be able to transmit enough power but would have had to have it very tight (too tight for my liking). In the end the belt failled anyway. The newer pulley systems use a sprung tensioner which increases the load it can transmit and the belt life. I'll be using the 7 groove serp belt. It also makes it easy to change pulley sizes as I can use standard alternator pulleys and off the shelf belts.
That is what the missus is for!kiwicar wrote:.crayefish wrote:put some fairy liquid and water solution around the injector o-rings. if you get bubbles, they are leaking on boost
Zander
