Just my few cents worth...
The only advantage I could see of having 4 turbos would be less turbo lag as the turbos would have less inertia. But for all that hassle then you might as well fit a supercharger as it has no lag!!!!!
However if you did want to go down the quad turbo route... (like me you might like pain and hassle!) you could use Garrett GT12s.
They will put out roughly 100hp on bike engines (up to a max of 150 I think). They might just be small enough for you. They have an internal wastegate. OR you could use the GT15 which is the same size but varriable vane for even less turbo lag, however you would need a pneumatic system to opperate it.
ANOTHER problem would be the pulses from the exhaust - you'd have to carefully match which cylinders so they are as close to 180 deg appart as possible and not have too short a primary.
Zander
Quad turbo V8 + power limits??
