Exhaust Insulation On A Turbo Engine
john 215
Post by john 215 »
Involved with a twin turbo Rover V8 race car, on a shake down run found the paint blistering on the bonnet where the exhaust run very close, is there any reason why exhaust wrap cannot be used on a turbo engine :?: I know ceramic coating would poss be better but as ever cost is an issue :roll:
Cheers John
LIVE LIFE A QUARTER OF A MILE AT A TIME.
topcatcustom
Post by topcatcustom »
You can get blankets to put around turbos, but having seen how hot some turbos get I'm not sure if I'd want to cover it with anything!!!
john 215
Post by john 215 »
Thats what sort of concerned me :? Although full plumbed in fire system dont want to have to use it unless nec!!
Cheers John
Try this stuff under the bonnet
On the GT40 I have the bottom of the rear "bonnet" covered
Exhayst collectors are about 3/4 inch below it and after a run I can hold my hand on the fiberglass so it works
http://www.cbsonline.co.uk/heatmat-htmat-1567-p.asp
cheers
john 215
Post by john 215 »
Hi Ian,
Thanks for the reply, would be nice to keep the heat inside the exhaust but looks like a good solution. You actually see the paint blister up and then as bonnet cooled once lifted off the car it healed itself!!! One of those cars where heat is going to be a huge problem!
Cheers John
How about some bonnet vents to let the heat out?
john 215
Post by john 215 »
Hi Ian,
Got them already!! At slow speeds on twisty circuits not really enough air flow, more happy down the Mulsanne at 201 mph!! Not Silverstone Mickey Mouse practice circuit!
Cheers John
IainB
Post by IainB »
Ive always been led to believe that keeping the heat inalong the hot side is a 'good thing'?
Ive also heard good things about wrapping both the turbo (in its own blanket) and also the exhaust
Andy Frost runs blankets without any issues as do many many many people over on Yellow Bullet and The Turbo Forum
You can buy turbo blankets, and they do work just fine. Any decent turbo shop should be able to supply something suitable
AET Turbos or Turbo Dynamics I imagine.
or from the US, www.forcedinductions.com
Return to “Forced Induction”
