Having some problems maintaining a stable idle after reving the engine,
Currently running an Eaton M90 on a TVR 3.5l, Jag injectors/AFM and adjustable 4cu ECU.
The engine starts and runs great but is prone to cutting out if you come off the throttle quickly, have tried allsorts of tweaking but cant get rid of this issue......any ideas?
Idle problems
I have a similar problem - come off power/ decelerate through the gears and it cuts out. But "blip" the throttle as you drop into neutral and it idles forever!
I have never found out the reason and put it down to the cam and valve mix I am running on the std ecu - but it does bug me!
So if you find an answer please post it up!
Never noticed any flames - and don't get "loud backfires" as if there is excess fuel going trough to burn in the exhaust
