Does anyone know whether a weber 500 carb could be used if twin turbo'd?
James
weber500 carb and turbo?
not without modification as the weber is designed to operate under atmospeheric conditions, not the high pressure assocated with forced induction. You could probably modify it but it might be a pain. I ran 2 jag carbs in a suck-throu configuration in my twin turbo MG before I converted to EFI. Still have them in the garage.
Er, yes actually, I have a Janspeed kit. And I know of another one up for sale as well.
I'm still using the manifolds and turbos, but the inlet manifold, cross-over pipes, breather system, carbs and turbo-carb mounts are all in a box somewhere in my garage! If ya interested drop me a PM and I can sort some photos out for you. Where ya based?
