After having a browse on here I’m at a bit of conflict as to what exhaust system I need
Mine is a 3.9 efi v8 r reg 1997 so precat.
I don’t want it so loud it’s offending but I was thinking a straight mid pipe and leave the rear resonator in place
Will headers make a massive difference or just up engine bay temperatures and affect the starter motor
3.9 v8 exhaust options
Re: 3.9 v8 exhaust options
I run the stock sd1 exhaust manifold, downpipes and Y piece on mine, welded on a 2" connector and a single jetex mid size box and straight out the back on the pop, sounded just right to me
So thats where it went !
Was that with efi?
All the Landy know it alls day the efi needs a standard exhaust as it bla bla balanced
Is this true or just like the myth of the person putting there motor home on cruise control and making a cup of tea
For the 3.9 - tuned extractors do little extra over the standard manifold. Gains are to be made in the exhaust system aft of the manifolds - slightly larger diameter pipes and free flow mufflers make a noticeable improvement.
Thanks for the reply
Iv ordered a straight mid pipe so will see how it goes
I ran carb, rover efi, and fast efi on it, but the exhaust never seemed to mind what I was doing
