converting to hotwire injection...._
- Knows His Stuff
Well finally I think I've had enough of my carb as obviously it's heavier on fuel and down on power compared to injection!!! So, what would you say is a reasonable price to pay for a full hot wire setup, with sensors, injectors, loom, ecu, afm, etc..... And how difficult is it to get going on a sd1 lump that's on a Holley at the moment??
Jono
Jono
Bear in mind that the SD1 never had the hotwire system, it had the flapper system.
The hotwire system was used on the Range Rover / Discovery. I believe in 3.5l form it was only used on the Disco.
I don't suppose that it would be very hard to install, and if everything is in working order you'll be away! However, fault finding is quite difficult, so it's well worth reading up on everything about it before starting.
Re: converting to hotwire injection...._
Most of it simply bolts on. However, the fuel supply is very different - a high pressure pump with flow and return.Jono FD3 wrote:Well finally I think I've had enough of my carb as obviously it's heavier on fuel and down on power compared to injection!!! So, what would you say is a reasonable price to pay for a full hot wire setup, with sensors, injectors, loom, ecu, afm, etc..... And how difficult is it to get going on a sd1 lump that's on a Holley at the moment??
Jono
- daxtojeiro
- Forum Sponsor
As Dave says,
the hardest bit in the hardware is the fuel supply.
Fuel pump
Fuel return pipe to tank
Catcher tank (a lot of fuel tanks need these adding on to keep the fuel pump fed when turning fast or accelerating)
http://www.extraefi.co.uk/basic_efi.htm
If you can do some wiring then sell the Lucas loom (or dont buy it) and make a new one for the MS, if you go that way. All the connectors are available for reasonable money.
thanks,
Phil
Fuel pump
thanks,
Phil
IMHO you can save a deal of money by using a hotwire loom as the basis for a MegaSquirt one. They use thinwall cable protected by PVC sleeving which seems to survive the heat much better than flapper looms. Also includes a main and pump relay.
hi jono , is that your drift truck ?
how about LPG
before you laugh too much , you could get a flapper or hotwire manifold .. and a simple single point lpg setup , vaporiser / mixer ring etc and stick it straight onto the plenum no injectors , no elecrics , no ecu etc etc .... no airflow meter ...
it works ive done it ... infact im running it pretty much like it now on the road ..
i have a flapper system on it but ive taken the airflow meter off and just have a lpg mixer ring there instead , works a treat with no poxy afm in the way .. if i get low on lpg and theres no filling station nearby i just pop the afm back until i fill up with lpg
how about LPG
Ah, well, not sure LPG would work well with a drift truck. I find that if I am less than 1/2 full and I weave around, I can get the LPG to slosh around and move away momentarily from the feed pipe. Then the vehicle will switch back to petrol!
