Finally took delivery of my twin plenum that I'm going to modify for FI, my question is:-
Will the twin plenum and trumpets fit on a 5.0 ltr TVR manifold?
The reson I ask is I've been offered one for free and if they have the same size ports in then it'll save me maching the twin plenum injector holes.
Jeff
More twin plenum questions
If the 500 manifold is standard it will have a standard 38mm opening at the trumpet base end. If it has been ported it will be 44mm approx, the twin plenum trumpets are 42mm, so you are better off port matching a manifold to the trumpet base or have bigger trumpets fitted.
HTH
Edited to add
The twin plenum trumpet base will bolt straight on to the hotwire manifold
HTH
Edited to add
I'm going to collect this week, it's come from a burnt out car so there's not a lot of it left. When I last looked at it it certainly looked larger on the inlet (where the butterfly is) and the plenum from memory looked bigger.
My plan was to use the bottom half with new injectors and use the hotwire fuel rail. I'm not so worried about the step up in bore size from the trumpets to the manifold as it's being force fed with twin turbo's so shouldn't have too much of an effect
