rv8 exhaust sound???
minor8pot
Post by minor8pot »
hi i have a rv8 vittesse engine with a cam,edel inlet and carb with headers,going into a 3"single pipe from y pipe back into a hks japenese rear box....when you start it its very quiet,even on idle you would be hard pushed to think its a v8,,,rev the car and yes its more throaty but does not sound right...put another way when you hear the old wedge tvr they sound really nice,and pop and bang down the gears...what can i do to get the raw v8 sound back...cheers...
a twin exhaust system
One per side of the engine
It means the pulses are uneven and that is probably the sound you want
minor8pot
Post by minor8pot »
do you really think that will cure it>>>i thought the wedge tvr was single box,and the griffith has the front facing manifolds into one pipe and therough the engine mount...??? and not twin...
i thought it was case of swapping the back box...mmm
Will Reeve
Post by Will Reeve »
My TR has two exhausts in effect, each side goes through it's own mid-box and back-box. There is a link pipe a few feet from the manifolds which I have been told is good for scavenging across the banks. The sound is that suberb un-balanced V8 noise!
My 5er in comparison doesn't sound of anything it's so silent! That joins the exhaust early on and has a single back box.
minor8pot
Post by minor8pot »
damn...only just had this exhaust done...
That sounds a bit odd Minor / Nige!!
I just fitted an exhaust to an MGB of my mates. It has blockhugger manifolds into a 2.%" Y connector. Then 2.5" pipe to a single box at the back.
She sounds very much like an unbalanced V8. And when cold she blows steam rings about 4 feet out the tail pipe!
Your back box may be too big in diameter??
My own MGB sounds really odd because it has two short 3" pipes from each collector sticking out behind each front wheel. When its cold it sounds like a machine form charlie and the chocolate factory. But when its warm it sounds evil :)
You do have to tit around a bit to get the exhaust note right.
What headers do you have fitted??
minor8pot
Post by minor8pot »
p38 headers in to y pipe then 3 inch to the back box...1 box...
topcatcustom
Post by topcatcustom »
I'd be suprised if single mufflers with twin inlets will be completely split and not a common chamber as it helps with balancing- mine has a big fat X-pipe, my headers go to 2.5" pipes and dont get any smaller the whole way through to the real steel turbo mufflers and sounds pretty good, burbles nicely and pops and spits like its going out of fashion when you lift the throttle, makes plenty of heads turn!
I think you HKS back box is the problem, stick it on a TT Supra and it will sound pukka, get a new muffler from Real Steel and it will probably completely change it.
TC
And I'm different
Pots 2 and 3 from each side cross over and merger with 1 and 4 from the other bank
this means you get alternate pulses down each rear box
Aids scavanging of cylinders and is a GT40 only sound
It actually is like 2 tuned 4 cylinder engines running in perfect harmony
Post by ian.stewart »
Stick a 3" Flowmaster on the back, and bin the jap stuff, thats all I run, soundswell enough to gain a few comments
THE SMOKING GNU
I suspect the japanese box is creating quite alot of back pressure, this will be making the 3" pipe act like a long expansion muffeler, net result a very effective silencer as the pulses are traveling back and forth several times along the pipe resulting in lots of small pulses cancelling each other out. As Ian says stick a free flowing box on the back to relace the restrictive one it should sort it out.
minor8pot
Post by minor8pot »
ok thanks fellas...
