Plenum Chamber Swap
richardpope50
Plenum Chamber Swap
Post by richardpope50 »
I am fitting a TVR V8 (Griffiths 500) into a Dax Rush and have the problem of having to cut holes into the bonnet because the EFI hose and AFM sticks out. As the engine centre line is biased to the passenger side, there is more room on the driver's side so can I simply turn around the plenum chamber 180 degrees?
I know ACT, etc, do various chambers but I want the easiest solution in this case.
Would I have to make any other changes other than unbolting and turning around?
Thanks for any suggestions,
Richard.
It will fit if you turn it around. However the plumbing of the extra-air valve or idle speed valve or whatever else is attached will obviously not fit any more. But it's not insurmountable. I have seen it done.
richardpope50
Chris, thanks and yes, the plumbing and loom changes are no problem.
Richard.
seight
Post by seight »
Can it all fit under the bonnet on the drivers side then?
I'm not sure I've seen a Rush with it that way round.
richardpope50
seight wrote:Can it all fit under the bonnet on the drivers side then?
Hmm. Not sure either and agreed, never seen it that way around either but the idea just came to me.
Actually at the moment I have an old 3.5 V8 with SUs in to get through the IVA test (hopefully in a couple of months) so once that is out the way the TVR V8 will go back in and I know for sure. I am only an inch or so out so at the very least it is a small bump I have to make in my bonnet.
Richard.
spend
Post by spend »
No problem at all if you swap the rocker covers around as well. Research the SC Power charger installations they did it to fit intercoolers on several cars IIRC.
Can you not just do what they do on the westfields:
I know westfield charge about 400-500 for it mind.
I've got a prototype one in the shed that I've cut up to see how easy it is to do and it didn't seem that bad - I could do it for less than westfield, but you are still talking around £200 + manifold.
richardpope50
Eliot,
Unfortunately the Westfield method will not fit in my installation and it seems I may just have enough room with turning it around. Thanks anyway.
Richard.
With a bit of engineering, you can lower the whole thing to give more clearance.
You can mill the manifold down a little, then take some of the trumpet base and then even a little of the plenum top.
The MGB V8 guys do this - found a pic:
http://www.britishv8.org/Articles/Image ... -EFI-1.jpg
http://www.britishv8.org/Articles/Rover ... re-EFI.htm
Not the one I was thinking of, but you get the idea.
richardpope50
Eliot,
It's the width, not the height that's the problem...
The engine is about 40mm more to the passenger's side off the centre line so the AFM and pipework should fit inside my bonnet. It may stick up a bit but I have a large scoop. I measured roughly today and it still may still stick up a bit but the cut-out will be less and probably easier to make up a GRP cover for.
Thanks again.
Richard.
Right. Just turn it around then.
Whats the story with these connectors? - are they waterproof?
