What is this?
- Pocket rocket
What is this?
Here is what secures the crank pulley on my 3.5 RV8 (11D......).
I've never seen one like this before but have been told it could be for a starting handle type attachment. Has anyone come across this type of thing before? Any info gratefully received.
Does anyone know what size nut this is (there is actually a hex at the back but I haven't got a socket to fit over the weird bit on the front
[/img]
[/img]
[/img]
[/img]
yes that is so you can crank it over with a handle, though i really doubt anyone has ever started one with the crank handle. No idea what size spanner it uses.
Please tell me you are not going to put that revolting rusty crank damper on an engine. . . are you?
best regards
best regards
- SimpleSimon
- Pocket rocket
The receptacle ramps away from the direction of rotation and that stops the crank handle taking your hand and arm with it when it lights off. You also need to join the party and remove the crank once it's running. Some older cars had the crank permanently fitted with a spring to disengage it and keep it away from the pulley.
We had a Lister generator on the farm when I was a kid and it was a real bitch to start sometimes, particularly when it chose to backfire.
That drove home the physics of a scrawny 10 year old versus this....
and woe betide if you lost hold of the crank when it lit off.
and you have to hold the handle with your thumb on the same side as your fingers or you run the risk of this http://en.wikipedia.org/wiki/Chauffeur%27s_fracture if it back fires!
best regards
best regards
- richardpope50
- Gold Member
Am I the only one who has actually used a starting handle for starting cars?
At 12 I had a Ford 8 and an Austin 7 (on a farm) so both had to be started by hand when the battery was flat. owning two old cars on a farm taught you a lot!
Richard.
I could hand start my 2 1/4 Land Rover. In fact, I once bet a Boy Scout (aged 13), and he managed it.
I think if your timing is good, it's not so hard. Not so sure on these modern engines that need to be cranked at 400rpm to start though!!
Last starting handle I had was on the Morris Minor it used the same crank as the jack!
I only used it twice in the time I owned the car and it was a bit of bastard to hand crank!
We used to borrow my Uncle's old Bedford lorry and it needed cranking, but it was way beyond little me. I saw it dislocate one of the labourer's elbow once, so Dad banned me from being near it at starting time. I was allowed to drive it on level ground, in 1st gear at idle, because the pedals were out of reach.....richardpope50 wrote:Am I the only one who has actually used a starting handle for starting cars?
The 2 tractors were Diesel, so there was only pushing and shoving if those batteries went flat.
