![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Chevy Stroker 6.3L
Chevy Stroker 6.3L
Can anyone help me with a query, I have a 6.3 Chevy engine in my motor and I have taken the inlet manifold off as there was a slight oil leak at the back of the block (common problem I am told), anyway took the manifold off and found a spacer between the manifold and the cylider heads, its about 10mm thick and the heads have been re-drilled and tapped to accomodate the fact that is sits higher on the engine. Does anyone have any ideas as to what this is for and why was it done, I now have to get some gaskets made for it as well ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Has the block been decked? Or the heads skimmed? Or is the inlet manifold the correct one for the block/heads you have?
!0mm seems like a fair chunk for a spacer ...
If it is just a spacer then surely you can use the normal gaskets?
The issue is that the heads have been redrilled / tapped for the inlet manifolds, being higher on the engine then I cannot now remove the spacer
as the manifold wont fit. Yes it is the correct manifold as I have checked the part numbers etc its a TPI setup from a Corvette, found someone who can do the gaskets they are Ramgaskets and can do pretty much anything you need by all accounts.
I think it may be an Overfinch modification as they do seem to do some very strange things but if anyone can shed any light on it I would be grateful.
![Sad :(](./images/smilies/icon_sad.gif)
the most likely situation is that the heads are Vortec and the inlet is for the earlier style, how to tell is to look at the bolt pattern for the rocker covers, Vortec have center bolt holes, the earlier heads have the bolts around the side. Bolt holes for mounting the two types of manifold to the heads differ and the inlet manifold faces (normally) have different angles to the mating facesand the ports are higher above the deck face on vortecs your saying the plates have been bolted in place makes me thing that this is the case. They have probably had the head faces machined back to fit the adapters and make everything fit. I am left a bit puzzled as to why this would all be done though, Vortec style heads with mating faces that will match the earlier style have been around for a fair while and are pretty cheep, and then why fit the dreaded TPI set up
The other thought is that this is in fact a LT1 block that has been rebuilt as a "normal" chevy small block, does it have a conventional distributor of the odd set up on the front of the crank around the timing cover.
![Confused :?](./images/smilies/icon_confused.gif)
No dizzy at all and from what I managed to see of the engine casting numbers I think this is a Mexican block which would be right for Overfinch as thats what they used (well mostly), so do you reckon I could get a different inlet manifold and it would fit or do you think it may have been too far modified for that?
When I say TPI its got the 8 injectors but an MS2 that drives them and the sparks so its not really a TPI, oh and yes it does have Vortec heads, that I got from the head casting numbers.
ooh I think I guessed right then
The most likely approach will be that they have done all the modifications to the heads so they can just bolt on any older style inlet manifold.
Where are you based? my inlet manifold is off the engine at the moment, it is for the older style heads and we could check it against your engine if you want.
Good idea dumping the dizzy by the way. There is little wrong with the Mexican blocks once they have done about 30K miles, if they have Quality control issues they generally surface well before then, they are also a good bit lighter than the earlier US blocks and can still be bored at least +40 thou is it the later block that takes a roller cam as standard?
best regards
![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Laughing :lol:](./images/smilies/hahahaha.gif)
best regards
that is a bit of a shame I was in Sheffield at 3 30pm this afternoon I could have come and said hello!
Anyway looking at the pictures it is Vortec heads and a TPI manifold (earlier pattern). With a 6.3l (383 ci engine) and a TPI manifold it shouldn't be lacking grunt!
best regards
best regards
Ok some more advice needed as I cant seem to get what I need from Google, is there a UK supplier for Chevy TPI gaskets? I need all of the standard inlet manifold gaskets as well as the custom ones.
Think maybe I am looking and not seeing![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Range Rover 630R or otherwise known as the Money Pit
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
the inlet manifold to head gaskets will fit provided the holes for the ports are big enough, just measure the hole and look on real steel for a match and part number, the inlet manifold includes the rubber thingies at each end and the distributor gasket. Other gaskets are quite a lot more specialist, look for a 307 corvette around 1984 ish should be about right or make your own. . . may be simplest in the long run. Got some pictures of what you need?
Yes was thinking of using Real Steel for the inlet gaskets, its really the TPI ones I cant find in UK, I suppose I could make them but what from ?
The ones on the car could be re-used but I dont like doing that as invariably you get leaks after that, I will try to get pictures later today
