cam timing
- barginbucket
cam timing
hi folks,just a quickie,installed a kent 224 in my 4,0 litre sd1,timed it as stock,just wondering if this is best set up for this cam, thankyou
nothing new there then
There would have been a data sheet that came with the cam, this sheet has the proper timing in it. Sock timing will be safe but probably not the best it can be. That said unless your willing to invest in some tools/vernier sprocket and a bit of time your probably best leaving it as is. There will be some power to be gained but it wont be much specially if the rest of the engine isnt optimised for it
- barginbucket
thanks for that advice katanaman,i've had the cam for years,no spec sheet,engine spec:standard 4.0lt short motor,224 cam[with vernier adj/sprocket]set preload with adj/pushrods,bvh[41.5/35.5] webber 500 and mallory unilite dist/leads,not really sure what performance to expect,does not seem much different to the 3.5 i took out,hence the cam/ign timing issue,thought i might be strangleing it somehow,maybe a cam change would be better for the spec,anyone used :
crower comp u pro cam v8 performer 1
sounds good[they all do] on v8Tuners site
thanks again,all advice appreciated,youve got to keep the gasguzlers going
- barginbucket
