no oil pressure
[quote here is a daft idea ive used a 4.6 timing cover gasket and there was one place where the gasket was straight and it looked like it should of circled something.[/quote]
The 4.6 timing cover gaskets are different than the standard SD1 type, and the difference is in the oil pump area.
You may be blocking off an oilport with the 4.6 gasket.
Jim
Jim
didn't i say that earlierthev8kid wrote:is the cover gasket blocking/part blocking the oil feed hole from cover to block???
As others say, is the relief spring working, and fully home ??
Have you tried spinning the pump, with the relief plunger removed...oil should fly out of it.
Dont think it would help posting pics up.....Not really sure if there is anything external, we could see to suggest posssible causes.
But if the oil pickup pipe is submersed in oil, and the pipe 100% sound leading to the pump, then its really straightforward. The pump should lift oil.
Its maybe a longshot, but if you have something like a vacuum pump ( I have one used to remove fluids )
On some cars I forgot to prime ( non RV8 ) or had trouble priming. I attached this vacuum pump to an oil gallery, and forced vacuum, whilst turning the pump. It was usually enugh to get oil into the pump, and the system working again.
- ihatesissycars
When you say you've packed it with vaseline how much have you used?
Everytime o've done it i've crammed it to point of bursting so theres absolutely no air at all then used a high speed drill and immediately given the pump everything the drill could give, creates more of a sucking action to help draw the oil up.
Ref the relief plunger i'd take that apart and meticuosly reassemble it.
Is the oil pump base new or old? All original parts?
What have you done to the engine? New bearings etc?
- davemgb
- Helpful or Confused
I don't think this is the cause of your priming problem unless you have damaged the pipe to top flange connection, but when you do get it going you will probably get oil surge problems because of the cut back skirt on the pickup. If you remove the sump again change to a full depth unit, you only need a 3 or 4 mm gap and bashing the sump is the best way to increase it.toughy V8 wrote: i also thought the sump looked dented a little so i cut cut three chunks out of the sides of the gauze carrier part of the pick up pipe, im also thinking maybe its sucking air somewhere
Only thing no one has suggested yet for the priming problem - is the pump gear firmly on the bottom of the drive shaft. I've never seen it in a rover but A series engines have suffered from the pump shaft slipping in the rotor - manufacturing issues at various times.
Dave, you prime the RV8 manually, using a drill and a tool, engage on the pump shaft. Relying on cranking speed and drive via the dizzy could take forever.davemgb wrote:- is the pump gear firmly on the bottom of the drive shaft. I've never seen it in a rover but A series engines have suffered from the pump shaft slipping in the rotor - manufacturing issues at various times.
So ensuring pump rotation, is easy, and obvious.
Which is why it can make it even more baffling as to why there is a problem. You simply know the pump is operting mechanically.
My understanding of the pump is it draws from the sump through a gallery.
The oil goes through the pump gears into a void
At one side of the void is a pressure relief valve
At the other is the filter then through more galleries to the important parts
Perhaps the pump is working but there is a blockage in the filter (how much vaseline is in there now?)
The pressure relief is wrking and dumping the ooil back into the sump
Try spin the pump without the filter on
Could be real messy!
I hope so and a new filter will solve the prolem
Still trying to think outside the box with this one, are you running a remote filter?? if so, you could have plumbed it the wrong way around, not normally a problem, but if the filter has a non return valve, you may be pumping against the non return, which will stop the oil flowing round the engine
THE SMOKING GNU
