![Image](http://i1346.photobucket.com/albums/p697/bish_bosh1/DSC03101_zpsmztdkkku.jpg)
Bearings break up on track due to low oil pressure
I just cant understand it, striping down engine why cant I see much damage to the bearings, in the strainer you can see quite a bit of copper and I would say about the same amount has been cleaned from sump, where has it all come from, bearings 3-4 are wore but it is just not enough, the crank has burn marks which can be repaired as it isn't scored, I was expected something with more damage for the amount of copper fillings and the noise the engine made from video..
Any suggestions where its come from
Current project
1972 mgb v8 4.6 roadster
- SimpleSimon
- Knows His Stuff
