ZF kickdown settings?
Hi Guys anyone have a manual on these boxes? any idea of how the kickdown is set up? thanks john
So thats where it went !
Well it had it's first run out today and it felt like it only had 2 gears !!!! after a bit of research, i foundthe looser i made it the lower rpm it shifted at, mind u 4000rpm shifts were pretty hairy !! i was wondering if it's still intact how close the crimped on ferrule comes to the end of the adjuster when the throttle is closed? ost of the borg warners stipulate this as an adjustment figure? john
I finally found something on the web, it supposed to be 0.25- 1.25mm between the ferrule and the adjuster, i went out with mine about an inch out and only had 2 gears and stunning performance, i need to alter the bracket to get it closer, i'm still about 10mm out and it gives a hell of a kick as it shifts up !! thanks for ur help, john
