I've got a 3.5 Rangie on LPG, and was wondering how much power/torque the ZF 4 speed auto box (and the LT230 transfer box for that matter!) can reliably take...
I'm toying with the idea of an engine swap for a non RV8 unit, as to get big torque, I want big capacity and it's cheaper to start with a bigger engine IMO!
Cheers, Martin
How much power/torque can a ZF 4 speed auto take
1975 Chevrolet Blazer K5 400ci Pickup
1990 Mercedes 420SEL
1995 Jeep Cherokee (non V8... Doh!)
Various bikes 'n bits
Building a 4-car garage
It's measured as a torque, it's around 330 or 350. But I can't remember if the units are Nm or lbft!
The 4HP24 can be build to be a mechanical box like the RR 'HP22, but is stronger. The only difference is that it's a touch longer.
I'll check the spec. sheet tomorrow.
Well reminded - thanks!
My German isn't great, so I can't remember the translation, but here is the spec sheet:
http://www.cowdery.org.uk/downloads/4hp22-spec.pdf
Also the exploded diagram from JP Automatic Transmissions:
http://www.cowdery.org.uk/downloads/ZF- ... iagram.pdf
I Thought the 4hp22 meant 220nm torque
and the 4hp24 meant 240nm torque.
I read the 3.9 already stretches it as standard, but I think it can handle lots more just need to take a close look at the oil temperature and keep it cool.
Ashcrofts are quite helpfull and can build a mix of 22 and 24 to work manually.
