sd1\lt77 racing clutches
karrionchris
Post by karrionchris »
Just come back from the pod and after having some good runs my clutch decided to start giving up and slipping on burnouts and launches.
Im about the chuck in an LSD so i think i might need a stronger clutch. anyone have any ideas of a stronger clutch that will still fit in an LT77/sd1 bell housing. don't mind spending a bit of cash but i dont want to spend everything.
Reliant Scimitar Se5a
4.6 rover v8
Post by ian.stewart »
Have a look on the Helix web site, Im running a clutch supposedly good for 300hp.
http://www.helix-autosport.com/
THE SMOKING GNU
DEVONMAN
Post by DEVONMAN »
The Mcleod 10.5 unit from Real Steel is good but you have to either have your flywheel drilled for it or buy their steel flywheel. The Rover pressure plate version is a 2400lb assembly but the Chevy version is 2700 with the same bolt pattern.
Regards Denis
karrionchris
Brilliant
Do you know if that will fit in the standard 2wd lt77 bell housing
4.6 rover v8
DEVONMAN
Post by DEVONMAN »
karrionchris wrote:Brilliant
Real Steel sell the Mcleod to fit the Rover bellhousing. The release system has to be in good condition as the clutch needs a bit more movement to release than the standard clutch.
Regards Denis
bigaldart
Post by bigaldart »
What he said :whs
