The V8 Owners Forum - Forum Index The V8 Owners Forum -
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
 GarageGarage   1/4 Mile Table1/4 Mile Table
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
How Much Gas With No Retard????
Goto page 1, 2  Next
Post new topic   Reply to topic    The V8 Owners Forum - Forum Index -> Nitrous Oxide Area
View previous topic :: View next topic
Author Message
1986 Ford Capri
PostPosted: Mon Mar 22, 2010 7:12 pm    Post subject: How Much Gas With No Retard???? Reply with quote
just wondering how much gas i can put through the 4.6 before having to use any retard,
The comp ratio is a lot higher now than i was running with the 3.9 engine..
_________________
Rotrex C38-91 supercharger and Cossie RS500 Intercooler @ 14psi of Boost. 404 RWHP, (4.6)
New Forged 4.8 V8 kitted out with the dogs Cajones of parts and a procharger D1SC. 2017 Very Happy
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
gelmonkey
Sergeant Monkey Face
PostPosted: Mon Mar 22, 2010 7:38 pm    Post subject: Reply with quote
Tony
The general rule of thumb is ....up to a 100 shot no need to retard,after that its 2 degrees for every 50 I beleive.
I'm sure someone will either confirm this or put me straight.
I personally think it's very much a case of suck it and see because each engine will be slightly different in assembly even though they may have the same guts as another engine.
Paul
Back to top
1986 Ford Capri
PostPosted: Mon Mar 22, 2010 7:40 pm    Post subject: Reply with quote
was just curious as was running 150 in the 3.9 (with retard)
now im running coil packs i got no way of retarding the ignition yet with current ecu firmware.
_________________
Back to top
1975 MG MGB GT V8
PostPosted: Mon Mar 22, 2010 9:27 pm    Post subject: Reply with quote
Coops!
I accidentally ran 200 on Sunday with no retard Smile
And last year I ran several times at 240 of gas without retard.
The times were al the same as well??
As Paul says. Same engines dont react the same way to gas!
Mine should run around 26 degree's all in on gas. But there is still the dilemma of do you advance again at high rpm??
So a 100 shot on your 4.6 should be fine. The ultimate test of course is to do a dyno pass and shut it off as soon as you shut the gas down. Then do a plug reading.
_________________
Back to top
1986 Ford Capri
PostPosted: Mon Mar 22, 2010 9:45 pm    Post subject: Reply with quote
i think i'll do a 75 shot with no retard and leave it at that lol
dont want to blow it up at the ford day now do i lol.
its my comp ratio that worries me running a lot of gas.
also need to get some gas though Sad
_________________
Back to top
gelmonkey
PostPosted: Mon Mar 22, 2010 10:38 pm    Post subject: Reply with quote
Perry
There's a word for you and that is
BARKING Laughing
P
Back to top
1975 MG MGB GT V8
PostPosted: Tue Mar 23, 2010 9:12 pm    Post subject: Reply with quote
Paul!!
I'm old!!
I'm allowed to forget to twiddle the little retard knob on the dash now and then Laughing
Last weekend I had gone through my burnout procedure at normal timing. I drifted towards the start line with my sanatogen pumping and then got pushed back because of a car stuck up at the big end. So I reversed and waited. Then I was called forward and forgot to twiddle my knob?
The second time I had done my burnout and when I hit the purge button the poxy purge solenoid stuck open. So I turned the bottle off and reversed off again. I jumped out and pulled the stanley knife off my belt and cut the wires to the purge solenoid. I opened the bottle and all was good. Now I'm freaking because I know I only had 3-4lbs in the bottle and I didnt bother fitting a spare. I must have lost a lot with the purge stuck open. But I thought "sod it" I can run out of gas and still be safe. By this time the Sanatogen was enhanced with Adrenaline. So I was sky high mate Smile
So I forgot to retard the ignition and I forgot to turn the line lock back on ???
I launched with 225hp of gas and 250hp of petrol and she hooked fairly well. But 2 seconds into 1st gear she let go. So I backed out and shifted to 2nd gear. Then I eased the pedal back in and as soon as the gas was full on (1.7 seconds) she let go again. So I shifted to 3rd and eased it back in. She still lit them up so I backed out again. Then I waited until the 1000 foot marker around 100 mph and eased the pedal back down again. This was not a good strategy to be honest!!
She actually hooked up and went really well for about 3 seconds and then the back end jumped up and I went a bit sideways??
I have now found a problem with the rear springs. They have gone flat Sad So under load my only suspension is the tyres ??
After backing out 4 times I still hit a 12.2 pass which I'm happy with.
But it does go to show that a wanked out stock 4.6 with crap compression will take a shed load of gas eh?
Thats my saving grace I reckon. If my engine was in good nick with 11:1 cr and valves that sealed up properly I might be in trouble Smile
I remember about 5 years ago being told by Real Steel that I should not put more than a 75 shot of gas into a stock Rover V8 or it will break Laughing
Now we have to examine the law of sod!!
I could build a pristine engine in a really nice car that I drive daily. I stick a 50 shot on and break it ??
Or I chuck together and old spunker that I drag to the track on a trailer so I can take it home in bits if it breaks, and it takes more abuse than it should ever do??
There is some logic to the "drive it like you just nicked it" theory
lol:
_________________
Back to top
1986 Ford Capri
PostPosted: Tue Mar 23, 2010 9:22 pm    Post subject: Reply with quote
i will be out to play this year Pel (as long as i dont break it again)
but i wont be giving you no trouble on the track, im far from your times now,
i can only dream Wink
_________________
Back to top
gelmonkey
PostPosted: Tue Mar 23, 2010 11:00 pm    Post subject: Reply with quote
Perry
You is still BARKING Laughing
You and I must have a good talk about gas one day.
I have a plan of running a 12 in my car once it is all base lined and there are things I would like to know but I won't hijack Tony's thread.
OLD and twiddling yer knob?
What kind of drag races were you at Shocked
P
Back to top
1975 MG MGB GT V8
PostPosted: Wed Mar 24, 2010 6:41 pm    Post subject: Reply with quote
Laughing Laughing
Coops!
I'll pit bitch for you mate.
Paul!!
I've broken enough stuff with nitrous to have some good background info for you Smile
Pel
_________________
Back to top
1986 Ford Capri
PostPosted: Thu Jun 03, 2010 5:40 pm    Post subject: Reply with quote
Pel cant find my 7's plugs (been a while since i ran gas)
i have BCPR6ES Plugs fitted, these to hot for 75 shot gas mate?
_________________
Back to top
1975 MG MGB GT V8
PostPosted: Thu Jun 03, 2010 8:20 pm    Post subject: Reply with quote
Number 6 does seem a bit hot I reckon. I've never gone below an 8.
I cant remember what the original V8 plugs are now??
But I used to run up to 100 shot on those.
I find the B8ECS a good all rounder myself.
_________________
Back to top
1986 Ford Capri
PostPosted: Thu Jun 03, 2010 8:22 pm    Post subject: Reply with quote
v8 standard are 6's
i was running 7's up to 75 shot i think,
then from 75 to 150 was running 8's
_________________
Back to top
1975 MG MGB GT V8
PostPosted: Thu Jun 03, 2010 8:25 pm    Post subject: Reply with quote
Theres your answer then mate Smile
_________________
Back to top
1986 Ford Capri
PostPosted: Thu Jun 03, 2010 8:38 pm    Post subject: Reply with quote
you ran 100 shot on standard 6's?
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    The V8 Owners Forum - Forum Index -> Nitrous Oxide Area All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Make payments with PayPal - it's fast, free and secure!
Copyright www.v8forum.co.uk 2006. All Rights Reserved,
Forum Disclaimer: Any posts in the V8 Forum are posted by individuals acting in their own right and do not necessarily reflect the views of the owner, administrators or moderators.
