After boring the plenum need to be sleeved.
By comparaison an standard 65mm plenum and 73mm plenum
I will have some available soon.ArneV8 wrote:Hmm, nice work!![]()
When can you do mine?
I did try welding one up and I wont show you the results - although that was one that had broke through already. I might have a go at pre-welding one whilst its still thick.katanaman wrote:nice work, would it not be possible to tig it up first and then machine it down? Seems like a lot of extra work having to sleeve it.
Take a look through my manifold archive for some examples:mooose wrote:Has anyone tried welding a larger throttle body on to a normal plenum top ?
Can it be done ?
