Intake pipework
- topcatcustom
Intake pipework
Is 1.6mm walled ally tube thick enough for low boost pipe work? Want to use 3.5" or 4" tube and it's only available in 1.6mm or 3mm wall.
TC
- topcatcustom
I had decided to go with the thinner stuff, but may do a couple of trial welds before ordering as butt welding thin ally can be a pain! I've found a company who will supply me with 3mm mandrel bends which would definitely be the easiest option as 3mm is easy to weld, but it would be heavy!
Oh- how could I bend the 3mm stuff myself?!
TC
