Plenum Spacer:
Our Plenum spacer is designed to improve air efficiency by increasing the available air volume to the cylinders, improving throttle response and overall performance.This is achieved by fitting the spacer between the plenum and trumpet base, resulting with an increased volume of 0.55 litres. A 15% increase in volume that improves throttle response.
Dyno results with the spacer have demonstrated an increase in performance of 3hp/4ft.lbs torque.
Please check the website for more information.
V8 Owners price £112.50+vat
Bell Mouth Trumpets
These bell mouth trumpets were designed to improve the flow of air into the cylinders. The standard headers are not equal length so the trumpets were cut down to equalise this distance. That in conjunction the bell mouths increases power by 3bhp. Cut down lengths are supplied with the bell mouths
Heat Wrap for AFM
Any car will benefit from using this heat wrap for their Lucas AFM, the units are susceptible to heat so any protection you can give it is a good idea. The wrap is simple to install as it just fastens with Velcro strips sewn into the fabric.
V8 owners price £27+vat
Engine mount restraint bracket
Designed to support and strengthen the existing mounting, the restraint has been developed for and proven on our Supercharged range of cars.
These restraints produced from high quality steel and electroplated for corrosion protection are now available for all RV8 engine installations.
Please check the website for more information on this product.
http://www.sc-power.co.uk/SC%20Power%20 ... 20Mods.htm
Just mention your V8 owners username to obtain the 10% discount
All prices do not include delivery
David Harvey
