Hello,
Do you know if it is possible to use high grade standard bolts instead of stretch bolts on later 4.0/4.6 rods ?
Thank
Alternative to stretch bolts on later conrods ?
Do you mean as in standard hex head bolt or standard rod bolts? If hex bolts then no there isn't any room for the hex on either the head or the nut. It also needs to be a fine thread for accurate torquing and clamping forces. I would imagine the shoulder could be quite critical as well to keep everything lined up properly. I didn't actually know they used stretch bolts to be honest. Don't like the sounds of that but then I don't like stretch bolts generally anyway. My top tip here would be to use ARP rod bolts.
Re: Alternative to stretch bolts on later conrods ?
Are the bolts on the rods strech ones then.Wotland wrote:Hello,
Thank
