Hi Guys,
looking at using the shorter water pump from P6 to my SD1 engine, need to pull the radiator back to make room at front for an intercooler for my supercharger install.
1. will the P6 pump fit the SD1, how much shorter does it make it
2. will the SD1 crank still be okay to use with a change to the pulley
3, SD1 alternator mounting , will it work with new P6 pump
regards
Andy
shorter pump on SD1 engine
There's two types of P6B alternator brackets, early for the 11AC alternator (although if you have enough room at the side of the engine you can get an 18ACR to fit) and later for the 18ACR.
I've just sold my last bracket to another member on here, but I'll look out for another one, there may be one hiding here somewhere.
