Check out page 116,
http://www.taperformance.com/www/PDF/TA ... atalog.pdf
Cooling Holy Grail,???
THE SMOKING GNU
On cooling
WOW ! Did I learn a LOT !
Each of you should go to http://www.stewartcomponents.com and read about Stewart Components and what they do.
THEN, start reading their 5 Tech Tips HERE -
http://www.stewartcomponents.com/tech_t ... Tips_1.htm
At the end of each tip there is a link to the next tip.
THESE 10 FAQ's are a MUST READ too.
http://www.stewartcomponents.com/Stewart_faq.htm[/quote]
Regretfully it's not Ian Stewart Components so we probably won't get a discount
It's an engine Jim.....but not as we know it
Re: Cooling Holy Grail,???
what? Do you mean teh elcetric water pumps on page 117?? The stuff on 116 are just standard water pumps aren't they?
- HairbearTE
- Guru
Ian they are very nice indeed and i'd be far more inclined to believe that those pumps would be up to the job compared to some of the little inline units you can get over here. The question is which timing covers will they fit? If they just fit the original buick design and not many of the later rover timing covers then not many of us are going to benefit. I would be suprised if they do one to bolt straight up to my intermediate cover for example, but if they do..
