I want to fit my 3.9 serp engine to my 110 with the twin carb manifold and LPG setup it already has in the car. The heater /lpg vap pipes I believe will run from the back of the manifold to the bottom rad hose tee, but what about the pipe below the thermostst housing which used to go to the back of the water pump? Block it off or tee it to the bottom hose also?
Thanks.
SU manifold on 3.9 serp engine
