v8 Radiator Suggestions
bigdawgv8
Post by bigdawgv8 »
Hi all,
Need your help and ideas again.
Just got my V8 up and running but the rad just isn't up to the job (a left-over from the cars 2 litre days!)
Sierra Cosworth seems popular but they're getting scarce and pricey.
Need something similar size to Cosworth - W 735mm, H 310mm, D 50mm
Can anyone suggest a suitable rad and fans for a V8 in Morris Minor..................???
Martin :D :wink:
Building 2 V8 Minors - double trouble!
Post by ian.stewart »
Plenty of people use Audi 100 rads, you can get them German French and Swedish
JP.
Post by JP. »
I am running a Sierra OHC rad for years now on our supercharged 3.5 without problems or what soever. Running the twin Sierra fans on seperate themp senders ( one left and one right ) and on seperate relays.
Have to mension that since we have an 16 row oil cooler with stat fitted the water temp is more stabil with outside 25+ degree Celsius temeratures.
bigdawgv8
Post by bigdawgv8 »
Thanks for the replies
ian.stewart wrote:Plenty of people use Audi 100 rads, you can get them German French and Swedish
What rad are you using Ian?
Martin :D :wink:
plastic orange
Post by plastic orange »
I use an SD1 rad in mine with twin kenlowes - cools just fine.
Pete
Image Image
DrDeAtH
Post by DrDeAtH »
you could measure up a transit diesel rad. that should be big enough
sidecar
Post by sidecar »
Pilgrim Sumos (Cob replicas) use sierra 2.3 diesel rad turned up side down!
I've a fairly hot 4.6 lump that runs at 77-80 degrees with the above rad.
Pete
dave350v8
Post by dave350v8 »
I fitted a transit diesel radiator to my chevy powered capri,works fine with two fans!
motherofgod
Post by motherofgod »
I also have sd1 rad with a single fan, no problems
James
Garth84x
Post by Garth84x »
will a radiator with a oil cooler at the bottom be happy to be upside down also?
garry
Audi rad in my baby,
Return to “Cooling Area”
