Is it possible to open up the blanking on the RR pump as my P6 has a pipe to both outlets .
I know you're going to say the RR pump/front cover won't fit but i'm not going to use the engine driven fan when the 3.9 goes in, and the pump will give clearance to fit one big electric fan behind the rad instead of two small ones mounted diagonally.
Range Rover Water Pump
