Can anyboby tell me where the two waterpipe connections ( I presume they are water pipes) that are beneath the air intake on the plenum chamber go and do I need them connected or can I just block them off?
cheers
Leigh
Water pipe connections on plenum chamber
- vdub boy 1
- vdub boy 1
You can remove the whole unit, but make sure you plug the two bolt holes at the back.
This will alow you to remove the rocker covers with out removing the plem.
Current V8 car TVR 400SE 240 BHP
Current Project TVR Tasmin Race, with 3.9 running at 230 BHP
Currently building a 4.6 300 BHP Xbolted Engine for it. Solid Lifters and Group A rockers, Stange 4 heads, Pocketed piston, fully balanced.
- vdub boy 1
