I'm putting an old Vanguard pickup cab on a Reliant Scimitar chassis, but with a Rover 3.5 V8 auto
Mild cruising use only.
Do folk think the 3L V6 rad could cope with the cooling demands of the V8
Jon
3L Scimitar Rad for Rover V8
It can be a bit marginal even on the stock 3l to be honest. If its in good condition and you duct it properly it should be fine. A better option is to take it to a radiator specialist and get it re-cored with an upgraded core. All that said with the different body on it you could probably fit a better radiator all together in there as you wont have the same space restrictions.
I would stalk ebay if I were you, if you have plenty of room something like this http://www.ebay.co.uk/itm/PWR-15-FPI-AN ... 2a264d72ea would be a bargin especially if you look for a while and set a budget not to exceed, they come up all the time and will seriously cool any rover lump.
