If the heater works, it means the water is running the opposite way through the heater (i.e. it is starting from the 'bizarre' connection behind the water pump.
You might find a 'stat with a bleed hole in it helps matters if you are getting air-locks.
Glad it's all working though.
Coolant path around the engine
I was also going to mention that - along with the thought that the actual pressure differential between the connections to ensure flow through the heater may also be quite low and therefore susceptible to continual air locking.
ChrisJC wrote:Another thought - if the heater is being fed from that extra port behind the water pump, that is where the water is at it's coolest. Not the most sensible place to take a heater feed from......
4.5L V8 Ginetta G27
