New water pump question
- truckdoctor
- Helpful or Confused
Can't seem to find a water pump for a 1968 rover v8 p5b, any good supliers known by anyone please?
Isnt this the same pump as MGB V8, Morgan 8, pre SD1 front cover type ??
Can you show a pic of the pump?
Perry
Perry
- truckdoctor
- truckdoctor
I wonder who is the well known supplier please? because I would like to replace it with a high volume type.harvey wrote:P5B & P6B use the same pump, which is the one you have. The one on the RHS in the pic of two is what is sold as a "High Volume Pump" by one of the well known suppliers, because it has double the number of vanes as the standard item.
J R Wadham.truckdoctor wrote:I wonder who is the well known supplier please? because I would like to replace it with a high volume type.harvey wrote:The one on the RHS in the pic of two is what is sold as a "High Volume Pump" by one of the well known suppliers, because it has double the number of vanes as the standard item.
But I tend to agree with:
Although for slightly different reasons, in that I've never found the standard one to be lacking in any way if the rest of the system is up to spec.kiwicar wrote:Hi
I would go for the one on the left, it looks a far better design, a proper flair transition into the impellers, a better gap between the centre bearing bit and the whole thing is made of ally.
Hi Steve , i got mine from JR Waddams about 18 months ago , no probs . Worth considering replacing the troublesome long bolts that go through the timing case with threaded stainless rod and nuts . No problems with snapped bolts in the future . Only down side is rad has to come out to remove water pump .
Stina
Edit . Thinking back got loads of other bits from waddams , but the pump came from Rimmer brothers .
Stina
Girls like V8s too !
- truckdoctor
Stina wrote:Hi Steve , i got mine from JR Waddams about 18 months ago , no probs . Worth considering replacing the troublesome long bolts that go through the timing case with threaded stainless rod and nuts . No problems with snapped bolts in the future . Only down side is rad has to come out to remove water pump .
Stina[/quoteThanks for that,good idea. The anoying thing is that I had the pump off recently to polish it and the bearings were OK then, hardly done any miles and they arenow rumbling away like a heard of elephants. Ordered a new pump from MG hive £59.
